Find intersection amongst Users
  • May 23, 2022
  • 376 views
Hi All,
In my application I will be exposing users to multiple Experiments.
we want to figure out number of times a user gets exposed to more than 1 experiment, and when they do we want to figure out the different experiments that they were exposed to.
As an extension we also might want to bring time/session into picture. Ex- If a user gets exposed to more than one experiment within the same session or within a fixed time intervalI(lets say 1 hour), we need to monitor that.
Do we have a standard way to accomplish this?
Best answer by belinda.chiu
Hi @c4code ! Welcome to the Amplitude Community and I’m happy to help! 👋
For your scenario, there’s not really a standard way to accomplish this as it will depend on your organization. The most straightforward way that I can see this happening is to instrument an event called Experiment Exposed every time a user gets exposed to 1 experiment and then an event property with the Experiment ID. You can then use cohorts and charts to build your analyses. There are a couple of things to note here though. First is that the Experiment Exposed event will count towards your allocated event volume. Second is that if you want to see this data on each individual user level, you will need to group by User ID on charts which may run into chart pruning: https://help.amplitude.com/hc/en-us/articles/360031259831
Hope the thoughts above help get you started!
belinda.chiu
Team Member
Forum|alt.badge.img+8
  • Amplitude Support
  • 189 replies
  • Answer
  • May 24, 2022
