Hi all,
I have user property with timestamp in `1619000000.571` format. That’s UNIX timestamp with millis as a float value.
I want to put that value in LONG_TO_TIME, but it doesn’t accept it in that format.
Tried SPLIT to remove 2nd part of timestamp, but SPLIT returns String, and LONG_TO_DATE doesn’t work with Strings. Which options do I have?
  1. Would be great to have STRING_TO_NUMBER function.
  2. Another option: mprove LONG_TO_DATE to support timestamps like that.
Thanks,
Ostap
Hi @ostap ! Welcome to the Amplitude Community :wave:  I’m happy to help!
I checked internally and found that you can get around this by doing DATE_TIME_FORMATTER (PROPERTY , "s","yyyy/MM/dd").
This help doc page describes how to use the DATE_TIME_FORMATTER function. In this case, I am telling the formatter we are getting a value in seconds (“s”), and I want a return format like 2021/04/21 (“yyyy/MM/dd”).
If you want to output to look like the LONG_TO_TIME function, then this “YYYY-MM-dd HH🇲🇲ss” should be the output format.
Can you try the above and let me know how that works for you?
Thank you, Belinda. It worked as expected!
Didn’t know about that `”s”` functionality in SimpleDateFormat. Thanks for sharing that internal workaround.
@ostap Glad to hear that it worked and you’re very welcome! :)
Our Derived Properties doc does have a handy link to the SimpleDateFormat functionality list. I’m going to share it here in case other Community members find it useful: https://docs.oracle.com/javase/7/docs/api/java/text/SimpleDateFormat.html
I agree with OP that a STRING_TO_NUMBER function would be useful.
Im my case I want to use "split" to pull a value from a longer string, then use math functions on it.
Hi @Jacobt ! Thanks for your suggestion and I think this would be a great add to our Product Ideas page: https://community.amplitude.com/ideas Can you share your feedback here?
