Hi I’ve been working on pulling revenue data and I’m a little confused by some incongruity I noticed in my charts. When I set up a chart grouped by $price and based on the TOTALREVENUE(A) I have one set of numbers for daily revenue then when I use that same user and make the chart based on “Properties: revenue” it produces another entirely different set.
From what does the difference in these two means of summarizing revenue arise?
Hi @jnazemi !
Thanks for writing in and happy to help! To clarify, are you wondering why you are getting different results when you look at RevenueTotal with $price property vs RevenueTotal with $revenue property?
If so, generally speaking revenue should be price times quantity. So if the event had a quantity more than 1, then revenue =/= price.
If you are seeing differences when using $revenue vs $price, then it’s likely the case that there are different quantity counts. Depending on what kind of analysis you wish to do, you would choose to either use $revenue (price x quantity) or just $price.
