how do create a graph of total signups (cumulative) and signups per day?
  • February 14, 2023
  • 894 views
i want to create a graph of total signups (cumulative) and signups per day
Please see sample below
Best answer by Matrak
Hello Karla,
You can use the “formula” option in the segmentation chart and use a regular formula (such as “Totals” assigned to your signup event) with a second “CUMSUM” formula (assigned to “Totals(signup event)”) which will compute the cumulative sum of your total signups.
Here is an exemple I made with Amplitude demo: https://analytics.amplitude.com/demo/chart/new/ilmz8vx?source=copy+url
The only issue is that you can only use the “line chart” option to get a similar result to your graph, and both your daily/weekly/monthly/quarterly signups and cumulative signups will share the same axis scales.
Hope this helps! 😁
Matrak
Peer Moderator
Forum|alt.badge.img+6
  • Peer Moderator
  • 20 replies
  • Answer
  • February 14, 2023
Hello Karla,
Hope this helps! 😁
Jeremie Gluckman
Team Member
Forum|alt.badge.img+9
Thanks for jumping in here @Matrak 😃
  • Author
  • New Member
  • February 15, 2023
Thank you so much @Matrak. This helps me a lot 🙌
