I’ve been having an issue where the cohort that I wanted to create keeps not getting computed. The cohort do have a lot of line condition but I was wondering if there are any limitations or ways that I can do to help compute the cohort.
Below is the screenshot of the data that has not computed. It usually happens when I want to substract a certain cohort.
Page 1 / 1
@Vania Alya welcome to the community! I’ve sent this along to our support team so they can dig into this cohort further.
Hi @Vania Alya, sorry to hear that you are having issues with cohort creation. I had a looked at the source cohorts and they do include a number of conditions, which can impact computation time. I tried building the same cohort as shown in your screenshot and it took about one minute to finish computing.
Do you mind re-creating the cohort and monitoring if it is complete? If not, I will escalate it to our Engineering team to investigate if needed.
Thank you!
Best regards,
Thao
Hi @Thao Nguyen and @Esther Trapadoux , thank you assessing this issue. I tried recreating the cohort and it generated the output but I couldn’t save this cohort. After a while, an error for saving was seen.
This error for not able to save the update to a cohort has happened to me a couple of times too.
Another thing is that, while waiting for saving I found the new cohort [Fix] Revenue that I wanted to save in my Cohort List. However, it couldn’t compute and eventually showed 0 user.
If I could get an insight and help regarding this, Thank you!
Hi @Vania Alya thank you for getting back to us! This looks like a bug. I’ve escalated it to our Engineering team to investigate why the saved cohort size is 0. I will let you know as soon as I hear back.
Apologies for the inconvenience!
Best regards,
Thao
Hi @Vania Alya thank you for your patience!
After taking a closer look, we found that the cohort [New] Referral (Retention + Refer Someone) is built based on the cohort [New] Revenue (Transaction > 1, diff verical), specifically it includes users from [New] Revenue (Transaction > 1, diff verical).
Therefore, you can’t add the second clause “not part of cohort [New] Referral (Retention + Refer Someone)” because these two cohorts conflict, resulting in the save failed and returned 0 users. If you chose a different cohort for the second clause that doesn’t have clashing conditions, it will still work.
I understand that the preview says more than 75,000 users who match the condition. Our Engineer advised that the preview runs a temporary computation of the cohort size when you make a change. However, it doesn’t run a thorough check for the definition until you hit Save. In this case, it errored out during the saving process.
Hope this helps! Let me know if you have any questions.
