Hello,
I was wondering is there a way to integrate WooCommerce and Amplitude.
I already have the Wordpress Amplitude plugin, but I have no date on my ECommerce tab.
If someone can help me on the setup, it will be useful.
Thank you,
Hi team Our AI visibility has not updated since November the 24th (when I signed up). Org ID: 391350
I have a csv with 2 columns user_id and lead_source. I went to Catalog and selected CSV under Lookup Tables. Step 1: I brought in the CSV and Step 2: I mapped the first column (user_id) to User ID (Amplitude User). It showed me a sample of my CSV and showed both columns at the bottom of Step 2. I clickd Finish. I went to…
I am unable to find my Event Properties in the list of “+ Filters” in Segmentation chart.
Myself and other team members have tried using the Facebook Cohorts integration however we always receive the same error ‘notifications.integration.saveFailure When looking in Meta Business Manager it says that the integration is active however when going into the Destinations tab in Amplitude, it is blank I have tried the…
I am setting user property wallet address, and using the same variable to set user ID. However, while walletAddress works (0xA66...54), User ID seemingly converts the hex to a big number (1.2905460614871781E+48) which is preventing us from using filtering and views. Any ideas?
