In the current experimentation UI in amplitude. we have the option to target all user or based on user property,
but what we need is to target based on specific event.
lets imagine that we have a funnel and
  1. Viewed landing page (first event in the funnel)
    Amplitude normally assign users on variants before or after this event get fired
  2. Clicked on product carousel
    this is the event that we want to start assigning when it happen to include only in the experiment users who have done this event and the variants (treatment / control) should get exposed after firing this event.
How to work on implementing solution 2.
is there is a way from amplitude ui or it should be done using code ? and if with code, how to do it ?
Hello Ahmed,
In Amplitude Experiment, the assignment to an experiment happens when the `fetch()` method is called in your code. This is usually done after you initialize the Experiment. The `fetch()` method triggers the assignment event, which indicates what variant a user was assigned to based on your targeting rules. A user must be assigned to a variant in order for them to receive the variant’s experience.
If you want to delay the assignment until users have completed specific actions in your product (like 'Clicked on product carousel'), you could adjust your code to call the `fetch()` method only after these actions have been completed. This way, the assignment (and thus the mutual exclusion) would only take place at this point, allowing you to run each experiment on 100% of the population.
You can find more information about the assignment event in this documentation.
I hope it answered to your question, if you have any other question, feel free to ask.
Best regards,
Ben
Note that Amplitude Experiment distinguishes between Assignment and Exposure.  And a user is only included in the sample set of an experiment if they have an Exposure event for that experiment. While Assignment is triggered upon fetch(), the Exposure event is not generated until the variant(flag_key) method is called. If your code calls variant() after the user clicks on the product carousel and uses the returned value to determine which experience to render, then everything works as you desire, there is no need to call fetch() specifically at that point. Only users who reach the point where the code calls variant() for the experiment will be included in the sample set.
Note: this is presuming you are using a client-side SDK with remote evaluation.
