I use a flag to enable user features in my app. I add user ids to the segments by UI.
I did it according to the doc: Working with feature flags and feature rollouts
But it is inconvenient with more users.
I would like to do it by API. I got acquainted with Experiment customers: New endpoints available for the Management API but I did not find an answer there on how to manage the list of users belonging to the segment. I can pull a segment for a flag but I can't change the segment.
Can I do it with the current state of the API? Maybe there are some other ways to enable/disable the flag for users via the API.
Flag management by API.
Best answer by Jeremie Gluckman
Thanks for reaching out here
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
analytics.amplitude.com analytics.eu.amplitude.comor
