400 and CORS Errors on a Experiment Route
  • September 15, 2022
  • 957 views
Hey !
Since 1 or 2 weeks I start to have a CORS / 400 Error on a specific route which is:
https://api.lab.amplitude.com/sdk/vardata
It happens only in dev / staging env (both same API KEYS) where it doesn’t happen in my production env.
I tried a lot of stuff: generating new API KEYS, removing all staging experiments, updating SDK versions, changing pc, network but nothing seems to change that, it seems to be related to the staging project/deployment on Amplitude Experiment.
It’s really annoying for my devs and me as it’s spamming constantly the console and as a dev, having errors in the console is just frustrating.
If you have any clue on that subject, please help me, thanks! :)
Best answer by Yuanyuan Zhang
Update from @Liroo:
Cause: On our staging / dev env we have a User property that is oversized. What I mean is that you seem to generate the `x-amp-exp-user` header based on User property we set in Amplitude Analytics and sending it to every experiment http request.
Without warning or error on your side you generate a large x-amp-exp-user header that you can't handle on your server as you answer a CORS Error where it's only a HTTP Header too large.
Workaround: reduce our user property
Update from Amplitude:
We will work on displaying a more clear warning or error.
Yuanyuan Zhang
Team Member
Forum|alt.badge.img+5
  • Team Member
  • 181 replies
  • Answer
  • September 22, 2022
Update from @Liroo:
