Hello,
I am trying to export historical data from Amplitude to BigQuery.
It works just fine, but I was able to pull only data from the last two months.
Is there a time or size limitation on historical data export?
Could there be a filter applied to the data?
Hi @OrHaskal ,
Thanks for writing in! So you have followed the article here, correct? You should be able to export all historical data to Amplitude. Can you let me know your ORG ID and Project ID so I can take a look? Thank you!
Can you also describe some of the data missing, such as with chart URLs or any other information.
