I don’t see in the ampli docs if methods such as ampli.track() return a status for success or not and was wondering if it does. Thanks!
Checked the implementation, seems like it doesn’t. So instead I would like to ask if it should return a success or unsuccessful value?
HI
Unfortunately, I do not believe it does return a status. Would you be so kind as to elaborate a little more on what it is you are trying to do ? I am more than happy to look around internally and see if I can find an answer for you, thank you!
