After running ampli pull in our project, we receive the following typscript error on 2 lines. It’s a very easy fix but it’s frustrating to need to change it every time we regenerate.
Â
Â
Â
Â
Sorry to hear that you are experiencing some difficulties using ampli with the TypeScript SDK. What version of the CLI and SDK are you using?
Hello
I’m using the latest version of the cli on windows:
We aren’t using the SDK, only the generated code from the CLI.
Hello
