We need to sum two user properties. Is there a way to get this? I’m guessing the best way would be to get SQL access, but short of that, is there any other way?
We’re not looking for event properties, just user properties.
Hey
Depending on how you want to interpret and use the sum, there could be couple of ways I can think of
Let me know if I have interpreted your use case correctly. Hope this helps!
