I tried to use Amplitude Node SDK on Vercel Edge functions. However, I'm receiving this error:
Can't resolve 'http'
I'm assuming that Amplitude Node SDK might not be compatible with edge runtime. Is there a SDK compatible with the edge runtime?
Same problem here - we are currently dropping down to raw HTTP requests [1] to solve this, but an edge-runtime-compatible SDK would be preferred.
Affects Vercel Edge, but presumably also stuff like Cloudflare workers, Deno Deploy, Fastly, etc
[1] https://amplitude.com/docs/apis/analytics/http-v2
