How do I deal with 'Unexpected' Event Properties
  • January 18, 2023
  • 2861 views
The Engineering team at our company recently added two new Properties to an existing Event.
I noticed these properties show up in Amplitude as 'Unexpected'. Do I hit 'Add' so these new properties are available to use in amplitude reports or is there something else I need to do here?
Also, is this a required step every time a new event or event property is added in the code?
Best answer by eddie.gaona
Hello @CarlB happy to help!
Unexpected means that the event/property was ingested into the project before it was planned within your tracking plan. I would agree with @Jeremie Gluckman to review the schema violation documentation.
Ingestion is not affected and to remove “unexpected” from the event/property you will need to add it to the tracking plan.
Jeremie Gluckman
Team Member
Forum|alt.badge.img+9
Thanks for reaching out here @CarlB. Here’s more information about handling schema violations - link. Please let us know if this helps.
eddie.gaona
Team Member
  • Amplitude Support
  • 161 replies
  • Answer
  • January 19, 2023
  • Author
  • New Member
  • January 20, 2023
Thank you @Jeremie Gluckman and @eddie.gaona this was helpful.
