Hi everyone,
Please see an attached screenshot of my visual labeling mode.
How can I change between navigate and label without pressing the button?
I opened a dropdown in my site in a navigate mode but when pressing label the dropdown closes. I tried to press Ctrl with the + button but it makes the resolution of my screen bigger…. Am I missing something here?
Thanks
Hello Etai,
Thank you very much for reaching Community,
If I understand correctly, you would like to select one of the element of the dropdown correct?
Would you be able to send me the html code of the dropdown so I can trouble shoot on my side and see If I can select one of the element.
I noticed that for a select I don't succeed to select the option inside the select but only the select itself, I am reaching out to our engineer regarding this one if this is expected behavior.
Best regards,
Ben
Hello Etai,
I just got an answer from the engineer team that might have some tips:
> I’m assuming in this dropdown is closing when you change modes? You can switch between navigate and selection mode using ctrl+/ which should allow you to select items in a dropdown
Tell me if it works I am excited to know 🙂
Best regards,
Ben
Hello Benoit,
Apologies for the late reply.
Unfortunately it does not work, the ctrl+/ method. It does not change the mode.
I also opened a ticket on the issue.
Thanks,
Etai
