Hi, I was wondering if there was a way to see top performing pages on our website based on conversion. I’ve built a chart for visits, but have not been successful for the conversion. Any suggestions?
Hey jai.andales,Based on what’s the definition of conversion in your use case, the Funnel Analysis chart could be a good place to start.
The following post will provide a bit more context :
Hey, played around with the chart I had and yeah the funnel analysis does a better job. Thanks Saish
