Max parameter data size for an event
  • November 5, 2021
  • 1318 views
Forum|alt.badge.img
Hi guys, we’d like to know what is the maximum character length is for the parameters we attach to an event?
We’d like to use this info to limit the amount of chars on the frontend to a sensible length. Couldn’t find this info in the documentation nor in public headers, so it might be prudent to add it there as well.
Best answer by Saish Redkar
Hey @markohlebar
The current character limit is 1024 characters for all string values.
You can read more about the various limits in here. Hope this helps!
Saish Redkar
Expert
Forum|alt.badge.img+10
  • Expert
  • 1377 replies
  • Answer
  • November 5, 2021
Hey @markohlebar
Forum|alt.badge.img
  • Author
  • New Member
  • November 5, 2021
That’s perfect @Saish Redkar. Thank you very much!
Anthony
Peer Moderator
Forum|alt.badge.img+2
  • Peer Moderator
  • 62 replies
  • December 8, 2023
Hi @Saish Redkar
We’re using the Kotlin Android SDK and for some reason my event property values for strings are getting truncated to 95 characters. The Android devs say they’re not truncating. Any ideas?
Thanks,
Anthony
Anthony
Peer Moderator
  • Peer Moderator
  • 62 replies
  • December 8, 2023
Nevermind! After consulting the new Support Chatbot AI, the devs were able to look at this and figure out where they were truncating it :)
