I have a mobile app which has a Menu (like a resturant) showing all the different "Meals" next to eachother like a resturant or netflix menu.
User can tap on a menu item, and it shows more details on that item, and then there's an "Order" button to order that item.
So I have 3 simple events: MenuItemDisplayed, MenuItemDetailsViewed, and MenuItemOrderered. Each event has a string attribute called MenuItemName.
I want to track performance and conversion on all menu items in one chart.
I can easily make one seperate chart for each menu item, but I have 30 menu items now so would need 30 charts. How can I make a "breakdown" based on MenuItemName to see which menu items perform the best or the worst all next to eachother?
I tried doing "group by" but it doesn't seem to work.
Hey ​@Drew Do, using the group by is how you would go about this, but there are some nuances. I assume you want to see the flow of each menu item through the whole funnel with the menu item staying the same throughout the whole flow? Perhaps the “holding constant” setting is what you’re missing?
This is a chart from our demo environment that you can look at live here
Let me know if this resolves your issue, and if not, please link your chart here with a note on what you’re expecting and I can take a closer look!
