Hello! Is there a place where I can see EU Amplitude integrations? I’m especially interested in the integration with Mailchimp and Databricks. I found this documentation link but I suspect not everything is relevant for EU version.
Thank you!
Hi Svitlana,
This is Yuanyuan from the Amplitude Support team - happy to assist!
It is correct that some integrations may not be available for EU orgs at the moment. You can refer to our source catalog or destination catalog in the dev center for official guides. It should be mentioned in the doc if the connection is not available for EU orgs.
I can see you have an EU org, so the easiest way to check it is via the Amplitude UI > Data > Sources/Destinations > search for integration. As long as the integration appears in the search results, it is supported for EU orgs.
I hope this is helpful to you. Please let me know if you have follow-up questions!
Yuanyuan
Hi Yuanyuan,
Thank you very much for navigating me, that was super helpful! 😀
Cheers,
Svitlana
