Hello Amplitude team
Understand that we can create a default user segment that applies to all new charts created in a project. However, is it possible to create a segment that is applicable to all new charts and updates all existing charts inside a project to this new default user segment?
In my case, I would like to create a segment based on an user property in which property values are often added and need to be filtered/updated. Hence, if it’s applicable only to new charts/analysis, it’s not practical since I would need to update the existing charts one by one.
Thank you
Hello Lucas,
Thank you for your question!
Currently, saved segments in Amplitude do not update across all existing charts in a project. If you change and re-save a segment, you must reapply them to individual charts for the changes to be applied.
As a possible workaround, you may use the Cohort feature. Charts built using these cohorts will be updated accordingly whenever you change the cohort definition.
Kind regards,
Amplitude Support
