Is there away to copy a dashboard to another project without recreating the same dashboard for every project all over again?
Hi Cortney Ketchum ,
Select the project to replace.
Go back to the ellipses and this time select “Save onto Charts”. You will then get an option to “Replace with Chart Copies”. Select this so the charts on the original dashboard you copied do not change.
Cortney Ketchum quick follow up - if you anticipate doing this frequently, you may want to consider using a template for future scalability.
