I am trying to set up a Snowflake Destination connection using RSA Key Pair authentication, but the connection is failing. The login attempts do not even show up in Snowflake's LOGIN_HISTORY view, which indicates the connection is being rejected before it reaches the Snowflake database itself.
I have already verified that:
The role, database, warehouse, and schema for this new user are the same as another existing user who can successfully connect to Snowflake.
The existing user is also configured with RSA key pair authentication and is working correctly.
ββββββ
