Question
How can I create a cohort based on webpage domain accessed?
Hello,
My company’s web app uses subdomains to separate customer environments, in the following format: xxxxx.yyyyy.com.
How can I dynamically create cohorts based on the xxxxx value of a domain, so I can easily track statistics on a per-customer env basis?
Best regards,
Saish Redkar
Expert
Forum|alt.badge.img+10
Hi @Elias Hjellestad
Are you capturing this value in some user property or your page view event property?
You will need these to build your cohort conditions.
Hello!
Actually, I figured it out. I was overlooking the tiny “+where” button on the cohort builder, that lets me set a “Property = Value” check.
Best regards,
