Hello, I just ended by A/B test and decided to ‘roll back’ - not use the variant I tested.
However, i can’t remove the javascript from the page header right now due to other reasons. Is this ok?
Will any users be affected, or should I just remove the js script when I can and it’s not really that harmful.
Hello Eve,
Hope you're having a fantastic day!
If you choose to roll back the Experiment, the flag will be turned off and the rollouts will be set to 0%. Even if the code for the variants or the Experiment overall is still in the codebase, users won't experience a variant since it has been turned off. You can find more details in the documentation here.
-Eddie
@eddie.gaona can you please add that link for ‘here’ in your statement above? thx!
https://amplitude.com/docs/experiment/workflow/experiment-test#what-happens-when-your-experiment-ends
