Why don’t I see an option to set up a holdout group in my account? https://help.amplitude.com/hc/en-us/articles/13508918823835
Holdout Group option missing from UI
Best answer by tcaprio
Hi Jeremie! Thank you for reaching out. We discovered that the feature wasn’t yet enabled for our organization, but it’s since been enabled. We’re good to go!
Rich Text Editor, editor1
Editor toolbars
Press ALT 0 for help
analytics.amplitude.com analytics.eu.amplitude.comor
