I currently don’t have access to custom events.
I was wondering if I can choose multiple events
For example
I have current events that are being tracked and I want them to sit under an umbrella
The Title should be Document Management
Events List would be:
Document Register
Upload Document
Linking Documents
Essentially I want to map every action that happens inside the Custom Event and then be able to filter for it on a Chart Report.
Is this possible? As I understand in Data>Event the tags and categories are only internal.
yup, you can for sure do that. you are able to combine the needed events under a single umbrella
“When ANY of the events below are performed, it will count as user activity for this custom event.”
unsure about filtering by a specific event inside, tho
