Hi!
  1. Could you please tell me how to edit name of events on chart,
Hovering over a signature doesn't show the editor's pencil. my colleagues with the same rights have this option
  1. my settings pannel is on the left, how do i customize the settings panel from left to top?
  2.
Hi @Balzhan Mukhamejanova
  1. For the funnel analysis chart in the new chart control design beta, it looks like renaming of the event label in bar segments is disabled. I tried renaming on my end and wasn’t able to for funnel analysis. However, I was able to rename in other charts like event segmentation. This could be some UI bug IMO.
  2. You can switch to the old chart control design using the More → Opt out of new look
    You can try switching from the new chart control design beta to the old one and see if you can rename your event labels in your funnel chart.
thanks a lot! i did it
