Not all vents are showing up. Limit?
  • 1 November 2021
  • 107 views
Hi community,
I came across with very interesting case.
My Android app sends bunch of events but I see around 50. I do not see other events.
At the same time iOS app works fine.
Does anyone know how to handle this limitation on Android?
Thanks in advance, guys
Best answer by eddie.gaona 3 November 2021, 00:30
Hey @gleb.prischepa
I’m assuming both iOS and Android apps are sending events in two separate buckets. Are you able to see the Android events in the user stream or are they missing from the charts only?
Can you check if they are all approved in the schema and also the visibility is not set to hidden and none of them are in the block list?
Hello @gleb.prischepa ,
Thank you for writing in!
I have similar questions and suggestions as @Saish Redkar. However, if you could explain more on what you mean by “My Android app sends bunch of events but I see around 50. I do not see other events.” What does this look like? What events are appearing and which aren’t?
I would suggest having a look at your Govern page to check if any events have been blocked or deleted or the schema settings you have in place.
