Is there a way to see what was received here that popped the error?
even the code, anything would help
Thanks in advance.
Thanks in advance.
Hi
This is to show you the amount of times the type ingested was not an integer, I understand you want to see further into what values caused these errors? Can you send me a link to your data so I can have a look and see? Thank you!
Thanks Denis!
It appears we did change the type in a data branch but haven’t fully approved it
this solved it.
