How to change Timezone
  • June 7, 2021
  • 4385 views
Hello,
I’m currently testing with amplitude, and I’m not getting the time record according to the local timezone I’m in. Is there a way to change timezone?
Thanx in advance.
Best answer by MikkoKarvonen
Olaf Yi wrote:
Hello,
Thanx in advance.
Go to Settings (bottom left corner, in the navigation pane) → Projects → choose a project. You should see this:
Note that this is project specific.
MikkoKarvonen
Peer Moderator
Forum|alt.badge.img+3
  • Peer Moderator
  • 113 replies
  • Answer
  • June 7, 2021
Olaf Yi wrote:
Hello,
Thanx in advance.
