How does "offset" work?
  • 8 February 2023
  • 329 views
I have a funnel of “Contacted” to “Replied” leads for past 30 days, which should show me conversion rate.
Though I need exclude “contacted” events which were last 7 days and include those happened 37-30 days ago, but I want see all “replied” event during last 30 days.
I apply Offset when choosing data period (last 30 days + Offset 7 days). But I don’t see the right numbers.
Can anyone explain in details how “offset” changes my funnel?
Best answer by Denis Holmes 9 February 2023, 11:29
Hi @Elena Kozak ,
The offset feature does work like you explained where if we look at the last 30 days, and apply an offset of X, we will look at the last 30+X - 30 days. So your understanding is correct but can you link me the chart URL? I can look into it for you and try and find an appropriate solution.
