Funnel : Data range and conversion window
  • 1 March 2023
  • 134 views
Could you tell me about the conversion window and date range in the funnel chart?
Does the date range apply to STEP1 or the entire funnel?
For example, if I set up the following:
  • Date range: January 1 - January 31
  • Conversion window: 60 days
Is a user who generated STEP1 on January 1 and reached the final step on February 2 considered to have converted?
Thank you.
Best answer by Matrak 1 March 2023, 17:00
Userlevel 3
Badge +6
Hi @Mion Nara!
According to your conversion window, the conversion can happen anytime during the 60 days following each day within your date range:
  • A user who generated STEP1 on January the 1st and reaches the final step before the 1st of March will be considered to have converted.
  • This will apply to everyone who generated STEP1 from the January 1st to January 31.
  •  The last convertions will occur from people who generated STEP1 on the January 31 and completed the final step on the March 31.
(Correct me if I’m mistaken 😄)
Hi @Matrak,
Thank you very much for your reply! I appreciate it.
I could not find any mention of this in the user guide, so I was not sure.
Thank you for your detailed explanation!
