Event properties count and transformation
  • 4 July 2022
  • 117 views
Hi, I’m trying to understand how the usage of transformations affects the number of event properties counted in amplitude. Lets say I had 2 event properties I transformed, would the count of event properties then be 3 or remain 2?
Best answer by Yuanyuan Zhang 5 July 2022, 15:07
Badge +5
Hi @fraser_hurley
Thanks for posting this question.
The instrumentation limit is on the count of raw data, e.g. event types or event properties, which is not impacted by transformations at all. So in your example, the count will be 2 because you have two raw event properties.
Hope this clarifies!
