Event disappeared after approval
  • 8 April 2021
  • 161 views
Hello Team,
I have sent a new event to Amplitude, but not seeing it in the Events tab, but I can find it in the Home → Unexpected Errors page, then I approved the event. However it is disappeared, and couldn’t find it anywhere. Can you please help?
Thanks
@RaymondHo Hey! I can help out here. The new event, if it was not planned in your Schema, then it will show up as unexpected in Amplitude. If you add this to your Schema, then it should be removed from the Unexpected list. Since I need to have a better look at your project, and Org, I will send you a private message, so that we can continue the discussion there.
@daniel.balan ,
Yes, you right.
I added the new event into the Schema with [Plan Data], after I approved it.
All good now.
Thanks
