Hi everyone, really interested in exploring amplitude. We have a pretty extensive tech stack, are amplitudes all free? Or are they add on services? I can list our existing tools but interested in learning a bit more!
Hi
It really depends on what are your primary use cases and the plan you wish to be on.
I would recommend looking at the pricing page and exploring their Starter Plan.
Depending on how you want to import/send data to Amplitude and/ or export it to 3rd party destinations, there are several options which appear to be available under the Starter Plan.
How do you plan to ingest data into Amplitude?
Here’s a quick overview of how you can get started with Data Sources -
https://www.docs.developers.amplitude.com/data/sources/
