Hi there,
our current tracking plan contains properties defined as numbers with the integer checkbox being enabled. When generating the strongly typed Kotlin client, the properties defined as Int are being generated as Double. I’m not sure what has changed but it has been different in the past.
Any known bugs?
The same issue. All `Int` properties became `Double`.
