What we do with amplitude, apart from analysis, for the sake of product growth?
  • 31 October 2022
  • 110 views
  • What we do with amplitude, apart from analysis?
  • For the product growth, whether can we do anything / perform any other task with the help of Amplitude?
Best answer by Saish Redkar 1 November 2022, 19:36
Hi @Mithra B
That’s a pretty open ended question given the depth and breadth of impact you can create using product analytics and Amplitude.
I would suggest the going over the following resources -
You can also use the Solutions section at the bottom of the blog page to get a high level use case overview
There are definitely more resources out there, but these will help you get started. Hope this helps.
Yeah. Thank you @Saish Redkar
