When looking at User Sessions, are inactive events ignored by default or should I add the "Any Active Event" filter?
Hi
Are you referring to the User Sessions chart? If your Inactive events are sent with session id’s they will not be ignored by default so you would want to use the “Any Active Event” filter. This doc has more info on how we track sessions in case you want to have a look. Let me know any questions on this!
Hi
Additionally, hidden, inactive, and deleted events will not be included in the session length calculation. For example, let's say you have the following series of events:
Event A --> Event B --> Event C --> Event D
If Event C and Event D are hidden, inactive, or deleted in Govern, then the
max(client_event_time)
is taken from Event B instead of Event D.
Is it a bug?
Thanks for following up
Thanks
Thanks
Hi
Hi
Sydney form your support team said that inactive events aren’t counted, but that can’t explain how users can have 4 days of session time. Our users are supposed to spend 10mn/week on our product.
So maybe we created the most addicting app in the planet that people use more than Tiktok, IG and Netflix combined. Or maybe there is a genuine problem with session time calculation and inactive events.
If you see events connected by a line in the User Profile that does not mean it is part of the session calculation necessarily. It just means you sent the same SessionID values for those events and we will group by that value in the User Profile section.
Based on the charts Sydney shared back, it looks like the inactive events did not accrue any session time. Do you see something different on your side?
Also happy to take this through DMs if that’s easier.
analytics.amplitude.com analytics.eu.amplitude.comEnter your username or e-mail address. We'll send you an e-mail with instructions to reset your password.
