is there any way sending Product Monitor Alerts to slack instead of email?
Hi
I hope this helps
Yes! thank you.
i can’t seem to find the webhook tab →
- Click the Webhooks tab. This is where you can manage your webhooks, as well as your automatic and custom monitors. The owner of the webhook, managers, and admins can edit or delete webhooks.”
Can you share a screenshot where i can find it pleaase?
Ah yes! Navigate to your org settings → then projects → then select the project you have the custom monitor setup in → then click on webhooks from that project settings
Let me know if this helps!
Hi
If you navigate to the chart alert directly from the chart, you can authenticate your slack workspace connection from there, and select a channel to post the alert to.
Let me know if you have any questions!
