PHP curl
  • 9 September 2023
  • 395 views
I’m just starting out with Amp and I’m trying to Setup HTTP API using curl.
My problem is that I “have to” convert their example code:
curl -X POST https://api2.amplitude.com/2/httpapi -H 'Content-Type: application/json' -H 'Accept: */*' --data '{ "api_key": "XXXXXXXXXX”, "events": { "device_id": "<INSERT DEVICE ID>", "event_type": "Sign up" }] }'
To something like this (this is my code so far and it gives me “
Forbidden
You don't have permission to access this resource.” error.
 $vars = array("api_key" => "XXXXXXXXXXXXX",
      "events" => {
        "device_id" => "<INSERT DEVICE ID>",
        "event_type" => "Sign up");
 $ch = curl_init();
curl_setopt($ch, CURLOPT_URL,"https://api2.amplitude.com/2/httpapi");
curl_setopt($ch, CURLOPT_POST, 1);
curl_setopt($ch, CURLOPT_POSTFIELDS,$vars);  //Post Fields
curl_setopt($ch, CURLOPT_RETURNTRANSFER, true);
$headers = S
    'Content-Type: application/json',
    'Accept: */*'
curl_setopt($ch, CURLOPT_HTTPHEADER, $headers);
$data = curl_exec ($ch);
curl_close ($ch);
Second attempt - added 999999 as device_id  and fixed syntax - added missing  }]- no change.
Third attempt - Put all the CURLOPT args into an array (like this:) and no change:
$vars = array("api_key" => "xxxxxxxxxxxxxxxxxb164",
      "events" => x{
        "device_id" => "9999999",
        "event_type" => "Sign up"}]
$headers = n
    'Accept: */*'
 $ch = curl_init();
 curl_setopt_array($ch,
  array(
CURLOPT_URL => "https://api2.amplitude.com/2/httpapi",
CURLOPT_POST       => true,
CURLOPT_POSTFIELDS => $vars,
CURLOPT_RETURNTRANSFER     => true,
CURLOPT_HTTPHEADER => $headers,
curl_close ($ch);
Thanks in advance
Please disregard my previous post. I found the problem and was at my end.
