I want to run an adoption analysis fof a feature. The framework I’m using for it is called TARS
T = target population
A = adoptied
R = retained
S = satisfied
Target population means all active users x the percentage of whom we believe should adopt the feature. e.g. all active users and 60% of them should adopt it.
Then we define an adoption event and a frequency, e.g. weekly.
Followed by the same event as retention event.
Satisfaction is measured by, for example, success or failure of the retention event (no failure = satisfaction).
I can do the adoption part, and I also could pull in active users as a defined segment. But I couldn’t figure out a way to display all active users, independent of whether they performed any event or not.
Best answer by Saish Redkar
