How to adjust more than 2 retention events?
  • 3 August 2022
  • 24 views
Hi, is there any way to add more than 2 return events to be shown in the retention?
Or any other recommended chart, in this case, I have 10 types of products separated by event properties and I want to see each retention rate.
Thanks
Best answer by Saish Redkar 3 August 2022, 20:59
Hi @Chidada
The retention chart supports only two return events at this time.
I’m not sure if I understood your use case fully , but if you are trying to see retention across user properties then you can use the group by clause.
If you are looking at event properties, then you might have to create individual retention charts filtered on each of the properties on the return events.
