How to add data labels to funnel conversion chart?
  • 22 August 2023
  • 250 views
How can I add data labels to the Funnel Conversion chart once inserted into a dashboard?
I am surprised (and a little disappointed) by how different the chart looks in the “create chart” view versus how it looks when inserted into a dashboard. You lose a lot of first-hand information as it is “hidden” in the tooltip in the dashboard, and the dashboard is what would be shared.
Hi @Jasmine Smith
Which specific data labels are you referring here? Is it the absolute number of user count shown in the funnel chart segments at every step ?
If yes, then you are right. It’s a bit frustrating to lose that context when presenting in a dashboard.
