In the Amplitude chart builder it is possible to filter by page URL, but this page URL does not include query string parameters. For example if the page URL equals:
https://www.website.com/slug_1/slug_2?parameter_1=yes
I can filter the URL by `slug_1` and `slug_2` but I cannot filter by `parameter=yes`
Is there a way that I can access query string parameters within Amplitude visualisations?
Will
Hi Will,
Thank you for reaching out!
This is Liping Yin from Amplitude Technical Support Team. I am happy to help!
Yes you can use global match to get the URL, for example this chart matches url that contains parameter `cv=1737467032710` https://app.amplitude.com/analytics/numan/chart/new/gwqwzp1h?source=copy+url.
For more detailed instructions, you can refer to the Amplitude documentation on glob match with wildcards: https://help.amplitude.com/hc/en-us/articles/360051775171-Build-charts-in-Amplitude-Add-events-and-user-segments#modify-a-segment
**Please note:**
> If your URL contains `/` characters that you want to include in the match, use `**`. For example, to match URLs ending with `/events/`, you would use `**/events/`. More information on glob matching can be found here.
I hope this helps! Please let me know if you have any other questions!
Best regards,
Liping Yin | Technical Support Engineer
Amplitude
Thanks Liping, but that doesn’t really solve my question. I want to filter Page Viewed and the Link URL property you mention above is only a default property of the File Downloaded event.
If I use glob match on the Page URL property of the Page Viewed event, it comes up with nothing:
https://app.amplitude.com/analytics/numan/chart/new/6jiuaj1w
