Error decrypting exported data in AWS S3
  • 25 April 2023
  • 220 views
We have the following error in trying to explore the JSON file obtained by the data export: "the ciphertext refers to a customer master key that does not exist, does not exist in this region, or you are not allowed to access."
Has anyone had this problem? How do I solve it?
Best answer by belinda.chiu 28 April 2023, 19:46
Hi @lsepulveda thanks for writing in and welcome to the community! I did escalate your case to someone in our tech support team to look into. I’ll see what they can do to help you out.
 Hi @lsepulveda ! Based on the error message you are receiving, it looks like you are attempting to use KMS encryption for S3 exports. If so, it is the case that we do not currently support KMS encryption and this is a feature request! Please share your Idea in https://community.amplitude.com/ideas :) Thanks!
HI!! Perfect!! Thank you so much for your help.👏🏼
