Divide by Dynamic User Cohort within Custom Formula
  • 15 October 2021
  • 6 replies
  • 566 views
I am attempting to find the percentage of users in a specific cohort that performed a few events. So far, I am able to find this percentage by using the Formula feature within the event segmentation chart. I have 42,087 users within this dynamic cohort. To find the percentage, I can take the uniques from each event and divide by the number of users in my cohort. Is there a way to shortcut this so that I can just divide by number of users within the cohort itself? If the cohort grows in size, I would like to have this chart adapt without having to retype the number of users in the cohort for the formula each time.
Formula I am using
Instead, could the formula do something like UNIQUES(A) / ”Current Cohort Population” ?
Here is my chart for reference:
 https://analytics.amplitude.com/viasat/chart/6bo9mqb?source=redirect%3A+chart+saved
Let me know if you can help out!
-Anna
Best answer by jmagg 18 October 2021, 16:36
Hey @akrause
If I’m understanding your use case correctly, the best approach would be to use the ACTIVE custom formula for this, since you are interested in the percent of active users who performed the event.
Here is an example chart showing the formula usage.
You can also use the “Active %” metric instead of the formula to get a similar result, like this.
@Saish Redkar,
Thanks for responding! Your response works if I want to filter by Active users. But is there a similar shortcut if I want to divide my uniques by all members of the cohort (both active and inactive)?
Badge +6
Hi @akrause - we have had several customers write in with similar inquiries! At the moment, it is not possible to achieve what you are looking for since we don't have a metric to measure total # of users within a cohort at each data point. We would need to make some sort of Custom Formula along the lines of UNIQUES(A)/COHORTTOTAL(A) - but we don't have a metric for COHORTTOTAL at the moment. Amplitude is an event-based platform so we don't have a way to track users who do not perform events yet still make up a segment. Along the lines of @Saish Redkar’s recommendation, the closest workaround I can think of is to select the event of interest & Any Event on the left module and the desired segment on the right module, then use the custom formula UNIQUES - example setup here. Hope this helps!
@jmagg ,
Thank you! Is there a way I can send in a recommendation this feature?
@akrause
You can submit a feature request/idea for this in here.
Hi @jmagg and @jmagg  is there any updates on this feature ? is this now doable? thanks
