I created a set of default properties on the event, user, and group level and I would like to be informed if an event is sent to Amplitude without them.
The same goes for the formatting, sit should be lowerCamelCase.
How can I make it happen?
Hi
For the formatting option, you can configure this in your Data project settings
For your first request,
The “unexpected” tag in your tracking plan is useful in understanding if something extra got ingested with your events. But not quite sure if there is a direct functionality which can inform you the other way round.
Probably you can mark the property values for these default properties as “Required” and then see if you get unexpected tags if the values come in missing.
Thanks for your response.
What’s the impact of changing the properties to mandatory?
I’ve followed your recommendation regarding the change of properties mandatory, but It seems like the option to do so is not available for my group properties. Any idea whether that’s possible to do?
A follow-up question, do you know if it’s possible to be informed/ reject events that do not follow our guidelines? i.e. we follow the objectAction formatting, for example, buttonClicked
I haven’t tested this option specifically, but it should trigger something ( if it’s working as expected ) if a property marked as required comes in null. Let me see if I can dig more on this behavior.
Sadly, Amplitude doesn’t give the same level of love to group props as it gives to user props in the Data settings. So don’t think I can add more to that.
You should be able to configure that in the Schema settings
Thank you both for the responses.
For example, if the event was sent from a native then a certain person will receive an email notification.
Thanks for your support
Hi Yosimy,
What I mean by # 3 is that I would like to be notified once an events doesn’t meet our company’s guidlines (objectAction).
For example, if a new event is called clickedButton I would like to be notified and may be automatically blocked it since the correct name should be buttonClicked.
Hope it’s clearer now.
