 I need support from Amplitude in understanding architecture of Amplitude . I would also like to understand How datas are feed to Amplitude  , my  product works in Angular and I know on a high level , Amplitude is implemented in front-end side.
Hi @cnikhil
You can start from this documentation - https://www.docs.developers.amplitude.com/data/sdks/#how-amplitude-receives-data
If your product is a web app, then TypeScript Browser SDK ( or legacy JS SDK ) will be the best choice for client side event tracking.
For any server side tracking, HTTP API will be helpful.
Thank You @Saish for your instant reply
Yes, thank you @Saish Redkar. You’re the best! 😀
