Question
Filter does not work properly
  • 20 June 2023
  • 105 views
Got a question: found some bug while doing data tables with filter. When I am doing the filtration, Amplitude shows users that do not fall under stated filters. What might be a problem in such case?
Hey @Yuliana Turchyn
Are you filtering on an user property?
Most likely that user’s current value for the selected user property could be different than the value reported during the chart interval. This makes the user get filtered on both those property values if they have reported different values across the time interval, which is a common behavior in an event seg chart.
Hey @Saish Redkar,
The user’s property I am filtering on is unique, it cannot be changed across the time interval
